Inventor Forum
Automatic Update of Model Revision Number
9 REPLIES 9
Message 1 of 10
3935 Views, 9 Replies
When we insert a Revision Table to a drawing we have the option to update Revision Number property in the drawing. This property is updated whenever we add a Revision Row.
I want Inventor to update the Revision Number property in the model the same way.
If this is not possible, is there a way to automatically map the Revision Number property in the drawing to the Revision Number property in the model?
Please advise,
Yoni
Tags (2)
9 REPLIES 9
Message 2 of 10
bobvdd
What if the drawing revision does not involve a geometry change in the part,  do you still want to bump the revision in the part? Looks like a strange workflow to me but if you want to proceed with it, here is some iLogic code you can place in the drawing that changes the revision of the component found in the first view on the first sheet. Trigger the rule "Before save".
Dim odrawdoc As DrawingDocument
odrawdoc = ThisApplication.ActiveDocument
Dim odoc As Document
Try
odoc = ThisApplication.Documents.Open(odrawdoc.Sheets.Item(1).DrawingViews.Item(1).ReferencedDocumentDescriptor.FullDocumentName, False)
odoc.PropertySets.Item("Summary Information").Item("Revision Number").Value = odrawdoc.PropertySets.Item("Summary Information").Item("Revision Number").Value
Catch
End Try
Cheers
Bob
Bob Van der Donck
Principal UX designer DMG group
Message 3 of 10
in reply to: bobvdd
Hi Bob,
Thanks for the quick response.
When I added a rule in IV2011 iLogic Your code generated the following error:
" Error on Line 5 : Comma, ')', or a valid expression continuation expected. "
Unfortunately, I do not possess the knowledge to debug it.
Please help.
Yoni
Message 4 of 10
bobvdd
Are you sure you copied and pasted  the exact same code correctly? Especially this line:
It looks to me that one of the closing round brackets ")" might be missing in your copied text.
Can you check if you have "...False)" and not "...False" without bracket or something similar.
Bob
Bob Van der Donck
Message 5 of 10
MjDeck
in reply to: bobvdd
Bob,
 There seems to be a problem with pasting code directly from the iLogic rule editor to this forum.  I recommend pasting to Notepad first, and then copying and pasting from Notepad to this forum.
 Here's a simplified version of your rule.  This will work in Inventor 2011 and later:
odrawdoc = ThisDrawing.Document
Try
odoc = ThisDrawing.ModelDocument
Catch
End Try
Mike Deck
Software Developer
Autodesk, Inc.
Message 6 of 10
Mike / Bob,
Thank you.
The last code works perfectly (I transfered it through notepad just in case...)
This kind of straight forward right-to-the-point online support is something I can easyly get used to...
Yoni
Message 7 of 10
that's exactly what I was trying to develop!! the reason is quite simple:
the quickest way to up the revision for a component drawing is by adding a new revision line in the revision table, but when you have a BOM in assembly drawing it takes component MODEL revision, not DRAWING.. are there any other better solutions to the one in here?
code is neat and work great with 2011, thank you.
Message 8 of 10
So glad I finally found this thread. Been searching for this rule code for a while now. Works perfectly and is saved in my rules folder.
Thank you!!!!
Message 9 of 10
bobvdd
I am glad too that you liked the code 😀
Bob
Bob Van der Donck
Message 10 of 10
alex.vernooij
 Hi all
I used you code, and it works perfectly for parts (.ipt), thanks! But I cannot make it work for assemblies... does anybody know how to make it work? I am not familiar with Ilogic.
Thanks in advance!
Nerea
