Inventor Forum
Automatic Update of Model Constraints not working
2 REPLIES 2
338 Views, 2 Replies
Recently, when i add constraints within an assembly, the update doesn't occur until i click on the update button. It used to apply the constraint right as you do it and you could see what was happening. It also does the same when you remove a constraint. You don't see what happens until after you hit update.
This is very time consuming and a little annoying.
Any suggestions.
Thanks alot fellas.
Jake
2 REPLIES 2
robmatthews
You've probably got "Defer updates" checked for assemblies.
Check the assemblies tab on the Application options.
This is my signature, not part of my post.
Yep. Thanks. I was thinking that, but i thought that was only in drawings. Now I know. I appreciate your help.
