Show only
Search instead for
Recently, when i add constraints within an assembly, the update doesn't occur until i click on the update button. It used to apply the constraint right as you do it and you could see what was happening. It also does the same when you remove a constraint. You don't see what happens until after you hit update.
This is very time consuming and a little annoying.
