Hello, I am beginner in autodesk and VBA and got one little problem.
I already made my model in .ipt and want to change 3 parameters of my model via VBA macro. It works ok but only if I manually start macro in VBA editor/autodesk. But now i need to run this macro on startup when i open my .ipt file (document project).
I got an init error on my start up macro(cant change parameters(dimensions)of my model)
This is code in my Form:
Public Parameter As Inventor.Parameters Private Sub UserForm_Initialize() On Error GoTo ErrorHandler Set Parameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters TextBox1.Value = 10 * Parameter.Item("dlzkadiery").Value TextBox2.Value = 10 * Parameter.Item("diera1").Value TextBox3.Value = 10 * Parameter.Item("vysunvystupku1").Value Exit Sub ErrorHandler: MsgBox "Chyba pri inicializácii okna", vbCritical, "Chyba inicializacie" End Sub Private Sub ButtonUpdate_Click() On Error GoTo ErrorHandler If TextBox1.Value <> "" And TextBox1.Value > 9 And TextBox1.Value < 101 Then Parameter.Item("dlzkadiery").Expression = TextBox1.Value Else: MsgBox "Dĺžka diery: Zadajte hodnotu v intervale 10-100mm", vbInformation, "Zmena hodnôt" End If If TextBox2.Value <> "" And TextBox2.Value > 4 And TextBox2.Value < 61 Then Parameter.Item("diera1").Expression = TextBox2.Value Else: MsgBox "Priemer diery: Zadajte hodnotu v intervale 5-60mm", vbInformation, "Zmena hodnôt" End If If TextBox3.Value <> "" And TextBox3.Value > 4 And TextBox3.Value < 101 Then Parameter.Item("vysunvystupku1").Expression = TextBox3.Value Else: MsgBox "Vysunutie vystupku: Zadajte hodnotu v intervale 5-100mm", vbInformation, "Zmena hodnôt" End If ThisApplication.ActiveDocument.Update Exit Sub ErrorHandler: MsgBox "Chyba pri zmene parametrov", vbCritical, "Chyba parametrov" End Sub Private Sub ButtonDefault_Click() On Error GoTo ErrorHandler TextBox1.Value = 50 TextBox2.Value = 50 TextBox3.Value = 15 Exit Sub ErrorHandler: MsgBox "Chyba pri zápise defaultnych hodnôt", vbCritical, "Chyba hodnot" End Sub Private Sub ButtonExit_Click() End End Sub
and this is code in my module
Public Sub EditParamsAutoOpen() UserForm1.Show vbModeless End Sub
Fast help is greatly appreciated
