At the moment I use a form to fill in my title block. This works well. I would have to manually type in the scale - which is not much of a hinderance if I'm honest!
Then I thought about automatically updating the scale to the view scale, and upon reading blogs/posts on this topic, I found a little ilogic code that works a treat.
but what if I dont want to automatically update the scale? if I want to leave the Scale as 'NTS'? is there an option of using the first view scale, or typing in a custom scale? see image.
by clicking on Set Scale, the border updates to the model scale, but what i would like is for the user to be able to fill in NTS in the box below which will overwrite the Set Scale?
Hope this is clear!
Solved by fakeru. Go to Solution.
After playing about with the code as you outlined, I eventually got it working as you describe. Although I cant really see the difference from before.
But I am happy with the result, thank you for your time.
Merry Christmas
