Inventor Forum
Automated Machine construction
5 REPLIES 5
130 Views, 5 Replies
Is it possible to specify and constrain a certain number of instances of a part
determined by some variable? We build roller conveyors, and wanted to automate
our "standard" conveyor construction. The idea is that we would save time
continually making like conveyors. Say we wanted a conveyor 10' long with 6"
between rollers, and some other user input. IV would draw all the conveyor with
the right number of rollers and shafts, etc. Seems like a VB problem, but as I
am VB illiterate, and my company is small (read: poor), I was hoping I could get
some help from this friendly newsgroup. Thanks in advance.
Dave Jacquemotte
davej@autoconcorp.com
5 REPLIES 5
sounds like you need to use a component pattern which is associative to a
feature pattern.
if you have a cutout in a mount which is then patterned along the mount, you
can then associate a pattern of rollers to those cutouts. if the number of
cutouts changes, so does the number of rollers.
you should be able to do what you're hoping to without VB (just using some
parametric equations) unless there is some specific problem in the way?
col.
Good idea. Thanks!
Dave Jacquemotte
"AutoCOL" wrote in message
news:F19EFBBFD710158DC4F4B27AD71E161C@in.WebX.maYIadrTaRb...
> feature pattern.
> col.
I agree. You don't need VB. Control it by a spreadsheet and you can have
one model for a bunch of different sizes.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
"AutoCOL" wrote in
message news:F19EFBBFD710158DC4F4B27AD71E161C@in.WebX.maYIadrTaRb...
> feature pattern.
you
> col.
Why not a skeletal assembly which would eliminate both Excel and the need
for constraints?
-Ryan
Ryan Small
Solid Caddgroup Inc.
Authorized Autodesk Systems Center
Burlington, Ontario, Canada
Ph:905-331-9670 Fx:905-331-7280
http://www.solidcadcam.com
ryan@solidcadcam.com
"Sean Dotson" wrote in message
news:E5C360ECEEC7EAF62F8550CD01407198@in.WebX.maYIadrTaRb...
I suggested Excel as it's an easy way for multiple users to control an
assembly easily without knowledge of how it was constructed. Skeletal
modeling is a bit more advanced and has it's share of gotchas.
True, either will work but if it were me I'd stick with linked params...
Sean Dotson, PE
"Ryan Small" wrote in message
news:3BC79A2AC31343531802877344590DD5@in.WebX.maYIadrTaRb...
> for constraints?
> -Ryan
> Ryan Small
have
