I am trying to model foam insulation around a circuit board, that is set in a fixture, in an assembly. Is there any tool that will allow me to do this? I am trying to avoid modeling a seperate part with complicated geometry.
Solved by JDMather. Go to Solution.
Shrinkwrap or Derived Component and Sculpt.
Attach example assembly here (just a board and a couple of parts).
One part doesn't really make an assembly.
If the attached doesn't answer your question then make up a more substantial assembly.
The Sculpt command does a "flood fill" of enclosed volume.
