Inventor General Discussion
Distinguished Contributor
1 Kudo
Post 1 of 7
Autodesk Privacy Policy and welcome screen on every startup
356 Views, 6 Replies
12-19-2013 05:38 AM
I just upgraded 17 workstations to Product Design Suite 2014.
On one of the workstations, the Autodesk privacy policy and the welcome screen pop up on every startup.  I even tried running it as administrator first, but no matter what I do, those screens keep popping upm highly annoying for the user.
I already uninstalled and reinstalled the entore product design suite, this did not solve the issue.
*Expert Elite*
1,275 Kudos
Post 2 of 7
Re: Autodesk Privacy Policy and welcome screen on every startup
12-19-2013 09:29 AM in reply to: edarlak
If this is only happening on one machine only, when you installed the software, did you do a clean uninstall before the upgrade?
If not you might want to completely uninstall all Autodesk software (including the registry) and then do the complete install.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
1 Kudo
Post 3 of 7
12-19-2013 09:38 AM in reply to: Cadmanto
To not interrupt workflow, I am leaving 2013 software on the workstations until I get the latest version of the vault server setup, then we will all start using 2014, and I will go back and uninstall the 2013 software. I do not want to unistall all the autodesk software.
Yes, this is only happening on one machine, very frustrating...
*Expert Elite*
1,275 Kudos
Post 4 of 7
12-19-2013 09:45 AM in reply to: edarlak
My guess is that somewhere in their registry this is causing the screens to keep showing up.
What sounds strange is that screens like these usually give the option to click a "Do not show this again" button.
Best Regards,
Scott McFadden
1 Kudo
Post 5 of 7
12-19-2013 09:48 AM in reply to: Cadmanto
"What sounds strange is that screens like these usually give the option to click a "Do not show this again" button."
They both have check boxes yes, but the choices are not "sticking"  That's why I tried to run as administrator first, but still didn't work.
sigh
*Expert Elite*
1,275 Kudos
Post 6 of 7
12-19-2013 09:52 AM in reply to: edarlak
Weird!!!
I would when you do get to the point where you can uninstall the 2013 version do that on this one machine only so that there is no Autodesk software loaded then install 2014 and see if this fixes the issue.  This would include cleaning out the registry of all autodesk settings.
Best Regards,
Scott McFadden
New Member
0 Kudos
Post 7 of 7
10-02-2014 02:07 PM in reply to: edarlak
Post to the Community
New Post
