Inventor General Discussion
kakaboo
Message 1 of 4 (915 Views)
Autodesk Material Library lost...
915 Views, 3 Replies
01-27-2012 02:46 PM
Suddenly Inventor lost ability to access material library when tryin' to apply materials for realistic view. Basic library is still accessible, but advanced appearance fails with message: "!" Autodesk Material Library is not available. I swear it was available not long time ago...
How to guide Inventor again back on track?
Even more weird, in my case: having absolutely no clue I didn't do anything and the access to material library was miraculously restored later, without any warnings or reasons whatsoever. I can only guess that one of peripheral rendering applications (i.e. Showcase) - supplied in Autodesk Inventor Suite package - is messing with links.
Matthew.
New Member
andrecok
Message 2 of 4 (864 Views)
Re: Autodesk Material Library lost...
02-17-2012 02:59 AM in reply to: kakaboo
had the same problem (with lost pictures/textures 'not available' in style editor); found solution at:
http://forums.autodesk.com/t5/Autodesk-Inventor/Autodesk-Material-Library-is-not-available/td-p/3002...
"Figured it out, in the options under hardware switch from compatibilty to performance and the realistic and bump maps reappear, wierd, oh well it's fixed"
for me this worked.
andreas
kakaboo
Message 3 of 4 (856 Views)
02-17-2012 02:45 PM in reply to: kakaboo
Matthew.
New Member
valerie
Message 4 of 4 (802 Views)
03-26-2012 05:43 AM in reply to: kakaboo
I think you're on to something about Showcase being involved.  My materials library became unavailable in IV just after I'd been using Showcase.  I hope mine mysteriously returns also. :cathappy:
