Hello
in real world:
when Worm screw rotates about its axis the Worm Gear follows the rotation and starts to rotate
but
when the worm Gear rotates the system is locked (because the screw won't allow this rotation)
it should be the same in Inventor
but when we run the simulation
there is no lock to the system when the worm gear rotates
so is there something we did wrong?
or Inventor has this bug?
i want the worm Gear only to follow the worm Screw (as in real world)
and the worm screw to Lock the motion when the rotation comes from the worm Gear (again as in real world)
Hope to find an answer
