Inventor Forum
Autodesk Inventor wont install - error 1308
4 REPLIES 4
4684 Views, 4 Replies
It is not the first part of the error message
it is error 1308 Sourcefile not found program Program files\autodesk\inventor 2013\catalog\desktop.ini
I have tried EVRYTHING read the clean uninstall procedure, used the auto remove progrmam you make, used registry cleaners, removed every autodesk product.
I am at my wits end cant the write the words I want to say about this but I need a solution. Before I have to either do with out or reload windows.
Help
4 REPLIES 4
blair
Looks like registry entries, you have followed the installation requirements.
1.) Logged in with Administrative Privledges
2.) UAC slider set to lowest setting
3.) Some Anti-Virus software may require to be turned off and it's services stopped
4.) You are current on on O/S updates and hot-fixes
5.) .NET 4.5 is installed on the system
Possibly corrupt installation media...
Possible corrupt user profile.
create a new user on your computer (admininstrator) reboot log in as new user
Delta Tau Chi ΔΤΧ
It was a great suggestion but the exact same error message...what on earth now?
in reply to: blair
By the way I did follow all your instructions. As far as the install I also own 2012 and tried to install it and it gave the same message.
Hmm, lloks like it may have been the installer after all I tried it on my other computer and got the same message. I will consider this solved.
