Trying to use for the first time.
What am I doing wrong?
CK
I have a stupid question... do you have a file open?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Can you post a screen shot so I can see what you are (or are not) seeing?
Chris Benner
Image did not come through. Sorry.
Chris Benner
You can't post files via e-mail, if that's what you're trying to do.
Use this button:
Is INV maximized to take up your full screen or are you running with INV less than full screen? The reason that I ask is that I wonder if the part file windown was collapsed and it is "below" the bottom edge of the INV application window?
If you forget the tutorial part for a minute and click to create a new part, do you see a sketch window?
Hi Kumar53,
Another thing to try is to press: CRTL + 0 on the keyboard.
For some reason, on my system I have to use the zero key on the top row, and not the one in the 10 digit keypad area, in order to get this to work.
CRTL + 0 simply toggles the Clean Screen option (Go to the View tab > Clean Screen button.) Sometimes we accidentally hit that key combination and turn on clean screen without meaning to.
I hope this helps.
Curtis
Chris:
I think I have a hardware issue with the graphic card. I am going ask someone to look at that. I will get in touch with you Monday.
Thanks for your help.
Chuck
