Inventor Forum
AutoDESK Inventor Pro 11
11 REPLIES 11
Message 1 of 12
broy
662 Views, 11 Replies
I have installed Autodesk Inventor Professional v11.0 in my machine as a stand alone user. So AutoDESK vault is also installed on my machine. Now I am facing a problem the problem is that when I am trying to access some parts from content center library in Inventor 11 it denies with the below mentioned comment "AutoDESK Inventor 11 could not find the data management Server on local host".
Earlier I have faced the same problem and to recover the same I formatted my hard disk and then re installed the product after that I access the same. But same problem is arising now. Is formatting is the only way to recover the same? Please suggest.
11 REPLIES 11
Message 2 of 12
in reply to: broy
When you install do you disable your Anti-Virus software and Firewall ?
Do you de-frag your h/d regularly ?
Have you cleaned your Registry recently ?
Do you have Windows Installer 3.1v2 installed ?
You might want to try
Autodesk Vault
http://www.autodesk.com/discussiongroup-vault
news://discussion.autodesk.com/autodesk.vault
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by
fabricated insanity that nothing could be as mad as what passes for ordinary
living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:5588842@discussion.autodesk.com...
suggest.
Message 3 of 12
in reply to: broy
Hi Duncan,
Is your registry cleaning question implying that reg cleaning is a good
thing or a bad thing?
I have been informed by a very knowledgeable Microsoft person, that registry
cleaning is never a good idea and that some registry cleaning programs are
very destructive. Many of the problems referred to them (Microsoft),are in
fact caused this way.
....Lawrence
"Duncan Anderson"
wrote in message news:5588794@discussion.autodesk.com...
Autodesk Vault
Duncan
proving by
living."
stand alone
problem
center
Inventor
hard
same
Please
suggest.
Message 4 of 12
in reply to: broy
It depends which Reg Cleaner you use. Some of the Freebies without an undo feature
can cause nightmares.
Did your contact at Microsoft tell you about these
http://support.microsoft.com/kb/835821/en-gb
http://support.microsoft.com/kb/835818/en-gb
http://search.microsoft.com/results.aspx?mkt=&form=MSHOME&setlang=&q=RegCleaner&mkt=en-US
Duncan
living."
"Beerwulf" wrote in message
news:5589224@discussion.autodesk.com...
Hi Duncan,
....Lawrence
"Duncan Anderson"
Autodesk Vault
Duncan
proving by
living."
stand alone
problem
center
Inventor
hard
same
Please
suggest.
Message 5 of 12
in reply to: broy
Did it ever work, or does it no longer work?
This error indicates that either ADMS is not installed (in which case it
never would have worked), or has been shutdown. If you launch the Vault
Manager (its somewhere like "Start>>Programs>>Autodesk>>Data
Management>>Vault Manager"), do you see any content libraries under the
Libraries folder? Do you see a vault under the Vaults folder (you need to
vault to sign-in to in order to modify content in the content center)?
Dave Mink
Autodesk / Data Management
Message 6 of 12
in reply to: broy
Hi Duncan,
I passed on your links and got the following comments. >
"these articles were not written by MS"
"The articles set out below are articles created and/or produced
by Future Publishing Limited. Microsoft is not responsible for the content,
accuracy or opinions expressed in these articles"
" "excellent, free RegCleaner (_www.macecraft.com)." this is not a
microsoft product and............will bust the registry for at minimum
Windows Installer "
" we pulled the MS regcleaner years ago as it is damaging "
"I think I will have my content guy take a look at the articles to see if I
can have them pulled or edited."
.......................Lawrence
"Duncan Anderson"
wrote in message news:5589257@discussion.autodesk.com...
feature
Duncan
proving by
living."
Hi Duncan,
....Lawrence
"Duncan Anderson"
Autodesk Vault
Message 7 of 12
in reply to: broy
Just back up the registry before editing/cleaning. You can always restore
back to that point. I try to do it on at least a monthly basis, in case
something bad creeps in.
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
Hi Duncan,
....Lawrence
"Duncan Anderson"
Autodesk Vault
Duncan
proving by
living."
stand alone
problem
center
Inventor
hard
same
Please
suggest.
Message 8 of 12
in reply to: broy
Welcome to IT Department H**L. I used to teach these guys years ago... Most
have Blinders on to the real world and its problems. They should have a
sign on there door titled "Welcome to my Cave"
It's all about control without learning anything new. They will never listen
because they have the whole company snowed.
260-399-6615
AIP 11SP2, AIP 2008
news:5589535@discussion.autodesk.com...
Hi Duncan,
Windows Installer "
"Duncan Anderson"
feature
Duncan
proving by
living."
Hi Duncan,
....Lawrence
"Duncan Anderson"
Autodesk Vault
Message 9 of 12
cad_fun
in reply to: broy
Are you using a vault project file?
Message 10 of 12
in reply to: broy
It sounds like your MS guy is directly related to Bill Gate$
Windows and other M$ products aren't necessarily the best written in the world, so I
take their advice with a pinch of salt. Norton Utilities made a brilliant Reg Clean
and System improver that increased Windows performance and stability 1000 fold - no
more blue screen of death.
MS have to accept some responsibility for articles published on their web site or
are you saying (or is your MS guy saying) that MS aren't a responsible company ?
Duncan
living."
Hi Duncan,
Windows Installer "
"Duncan Anderson"
feature
Duncan
proving by
living."
Hi Duncan,
....Lawrence
"Duncan Anderson"
Autodesk Vault
Message 11 of 12
in reply to: broy
Duncan,
I think he is saying that if the information does not come from Microsoft
(referring to us), then it is not valid information!
What a hoot!
260-399-6615
AIP 11SP2, AIP 2008
"Duncan Anderson"
wrote in message news:5590115@discussion.autodesk.com...
site or
company ?
Message 12 of 12
in reply to: broy
No, but I am sure the person concerned would consider adoption.
>>world, so I take their advice with a pinch of salt. Norton Utilities made
>>a brilliant Reg Clean and System improver that increased Windows
>>performance and stability 1000 fold - no more blue screen of death.
For Peter Norton's original utilities, "brilliant" was truly earned.
However, for the last ten years or so, I avoid Norton progs.
>>company ?
No. I would not say that. I am a "man of straw". 🙂
........ Lawrence
Duncan
proving by
living."
Hi Duncan,
Windows Installer "
"Duncan Anderson"
feature
Duncan
proving by
living."
Hi Duncan,
....Lawrence
"Duncan Anderson"
Autodesk Vault
