I am new to Inventor 2014 Dynamic Simulation and would greatly appreciate more detailed information on making joints than can be found in the tutorials. This is one fantastic tool and I would like to learn to use it.
I do have a specific question. I made a simple simulation of a freely falling cylinder with rounded nose falling onto a transverse fixed cylinder using a 2d contact joint. The simulation showed the falling cylinder make contact and bounce back as it should. The output grapher showed the forces generated at contact on each bounce. I did some fairly simple physics calculations to see if my calculated forces were in the same ballpart as the dynamic simulation forces and they were within reason. When I changed material on the falling cylinder from steel to rubber the contact forces dropped. However, when I changed material on the stationary cylinder from steel to rubber, the contact forces did not change. Can anyone tell me the procedure used in dynamic simulation to generate these contact forces. Thanks for the help. Phil
Solved by ravikmb5. Go to Solution.
Attach your assembly here.
Get the Wasim Younis Book 2 from Amazon.com
This was an interesting assembly posted yesterday
http://forums.autodesk.com/t5/Inventor-General/Dynamic-Simulation-Parameters/td-p/4702905
@Anonymous wrote:Attach your assembly here.
100% concur.
Wasim Younis' book is the gold standard when it comes to dynamic simulation. There's probably nobody on earth who isn't employed by Autodesk that knows more - and can teach more - about how to use Inventor's simulation products.
Rusty
@pquenzi wrote:
... Still would appreciate any explanation on this post if possible.
Changing the Material wont help
Change restitution co-efficient properties in 2d contact will help to some extent
The coefficient of restitution (COR) of two colliding objects is a positive real number between 0.0 and 1.0
representing the ratio of speeds after and before an impact, taken along the line of the impact. Pairs of objects
with COR = 1 collide elastically, while objects with COR < 1 collide inelastically.
For a COR = 0, the objects effectively "stop" at the collision, not bouncing at all. An object (singular) is often described as having a coefficient of restitution as if it were an intrinsic property without reference to a second object, in this case the definition is assumed to be with respect to collisions with a perfectly rigid and elastic object. The Coefficient of Restitution is equal to the Relative Speed After Collision divided by the Relative Speed Before Collision
Thank you. I did play with the coefficient of restitution a little and I see how it works. Your comment about the second body being assumed perfectly elastic is basically what I was interested in. As long as I know what the assumptions are I'm good for now. Phil
