Solved by cbenner. Go to Solution.
Welcome to the forums.
Dimension text size, and any other of these types of settings are set and changed using the Styles Manager, found on the Manage tab. You can create and edit multiple styles for different purposes, and then set the currently enabled one using the Object Defaults setting.
This is a link to the help section on the style manager... to get setting s to be used in all of your drawings, set them in your templates.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?contextId=REDIRECT_IDD_OBJECT_DEFAULTS_PAGE
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
