Good Morning,
As of late I cannot open Tube and Pipe. It will freeze on the loading and then come good once again but will not load Tube and Pipe.
Is there a workaround to this issue. I have read on some other threads people having issues with this on Inventor 2014 and have suggested to remove some registry files which I tried to no avail. Now I'm at a loss asto what is the issue.
Is anyone else having this issue or this local and how could I fix this?
Geoffrey Reynolds
So far I have not heard of anyone else having this problem with 2015. Is it a consistent problem across all assemblies, or just with one particular assembly file? Have you loaded all updates to 2015, and /or tried a Repair install? As a last ditch, have you uninstalled and reinstalled Inventor?
If you've done all of this and still cannot get it to work, I might suggest a Tech Support case with Autodesk.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
