Inventor General Discussion
PKorb
Message 1 of 6 (737 Views)
Accepted Solution
Autodesk Inventor 2014 idw glitches
737 Views, 5 Replies
07-19-2013 10:52 AM
Ive come across several fairly bad glitches in Inventor 2014 and was curious if these have been addressed or if they plan to be addressed. when im using a model to make an idw or adding a dimension to an idw the drawings lines or the dimension lines will spaz out or strech across the screen. Also at times ,in the case of dimensions, the dimension will have numbers missing (for instance the dimension 149.3 might be displayed as 1 9. )If i select the view and move it, the lines will pop back into place, dimension numbers will reappear etc.
I have attached an screen shot to illustrate what im talking about. The white lines are just where i have erased dimensions. everything else is the glitch. Has this been encounteded before? Also its not spicific to this file/part. It has been a reoccering issue.
Distinguished Mentor
john.retzlaff
Message 2 of 6 (718 Views)
Re: Autodesk Inventor 2014 idw glitches
07-19-2013 12:38 PM in reply to: PKorb
Have you applied update 2?
Check for an updated driver for your graphics.
John Retzlaff
PKorb
Message 3 of 6 (702 Views)
07-19-2013 01:47 PM in reply to: john.retzlaff
I checked the communicationcenter in inventor and it says my version is up to date.
Unless im not looking in the right place.
*Expert Elite*
blair
Message 4 of 6 (668 Views)
07-20-2013 11:36 AM in reply to: PKorb
It only looks for SP's and not patches or hot-fixes.
The upper portion of this web page has a support tab. That will take you to the products page, select Inventor and then Knowledge Base. You should then be able to navigate to the downloads page and find your product and the updates for it.
IV2015 up2 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
PKorb
Message 5 of 6 (646 Views)
07-22-2013 05:10 AM in reply to: blair
thank you. Its been downloaded and applied.
Ill mark as solved until i have any further issues. thanks again.
New Member
chriskulig
Message 6 of 6 (287 Views)
01-13-2014 01:08 PM in reply to: PKorb
cool!
Announcements
Need installation help?
