How to convert files that are designed in Autodesk Inventor 2013 to run in Autodesk Inventor 2012?
Thank you.
You can't. The closest you can come is to export from 2013 to a neutral format like step and then import that file.
@Anonymous wrote:How to convert files that are designed in Autodesk Inventor 2013 to run in Autodesk Inventor 2012?
Thank you.
Thank you.
