I'm trying to run Optimization on a part using IV2013 with SP2.
I get the attached message.
VAR support suggested uninstalling all SP's and Updates, then installing SP2 again, but this didn't work and I still get the original message.
I'd thought about re-installing Update 1 but it has been removed from downloads section.
Anyone have any thoughts?
Thanks in advance.
Solved by DarrenP. Go to Solution.
Would you please tell us your install workflow (the order of SPs and Updates) ?
Harrison
Hi Harrison,
I'm not sure exactly the order of install as I tend to install updates when prompted by Autodesk.
From what I can find SP 2.0 was installed on 14/05/2013, SP1.1 installed 18/10/2012 and Update 1 before that.
Be interesting to see what you come up with as VAR has drawn a blank.
We have validated that your issue can be reproducible with RTM + SP2 install workflow, SP2 missed a file that will update the one in RTM, please wait for the solution.
Sorry about that.
Harrison
My problem is about the same but It pop a message asking me to install SP1.1 which I did, and now my update is SP2 but the optimization is still unable to work.
Message : Update 1 for Inventor 2013 SP1.1 is required to keep using the Optimization service. Please go to www.autodesk.com/invopt2013update to get the update.
But the web address no longer available... thus I manually downloaded SP1.1 and SP2 to install but it still doesn't work.
So your problems are the same, sorry for the inconvenience, please wait for the solution
Is anything happening about this?
here is the fix: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21881225&linkID=9242018&CMP=OTC-RSS...
DarrenP
I get this error message on inventor : Update 1 for Inventor 2013 SP1.1 is required to keep using the Optimization service. Please go to www.autodesk.com/invopt2013update to get the update.
I have installed the 2013 SP1.1 several times now but it still doesnt work. What can I do?
