I am a student trying to get the student version of Autodesk Inventor Profesional 2013. I am running Windows 7 profesional 64 bit. I am an administrator on it. I have the most recent version of Microsoft .NET framework. I am trying to install Autodesk Inventor Profesional 2013 and when it is almost finished installing I get an "Error 1920. Service 'Autodesk Moldflow Inventor Tool Suit Integration 2013 Job Manager' falied to start" message. I have tried numerous troubleshooting methods including turning off antivirus, firewall, and UAC, nothing seems to have any effect on the installation. Any suggestions to fix the issue? and check some solutions that are in the Autodesk forums but I do not work I can do?
and use sitema RegClean and restore the sistem but the problem still continues...
Check the links here: http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-and-Windows-8-Compatibility/m-p/39...
The latest .NET framework is 4.5 but Inventor 2013 only supports / uses .NET 4.0. I expect you will need to remove 4.5 to get the install to work. If 4.5 is installed after Inventor 2013 is installed you will also need to install Inventor 2013 SP1.1 and SP1.1 Update 1 which adds support for .NET 4.5.
Regards
Martin
revice already but I have the. NET Framework version 4 here is the picture.
I can do?
my mistake, 1920 error pops up due to lack of privideges or a service failed to start, since you stated you were Admin on the machine, I ruled it out.
Maybe try RBM on the setup.exe file and trying the "Run as Administrator" option for the install.
Po
not very well understood the instructions. what should I do? pleas helpme
On the install file "setup.exe" , right click the file and select run as admin
You might have some better help from the pro's over here at the Installation and Licensing forum...did you post your problem there??
