Hi everyone,
I work with Autodesk Inventor 2012 and PHC Manufactor 2012 but I have to create 2 times the same code ... I will explain...
1º Autodesk Inventor -> Create the 3D (.iam file);
2º Create 2D (.idw file);
3º Open the program Manufactor 2012 (with SQL Crystal connection);
4º Create new file code in the manufactor 2012...
The point is, I have to create the code for the 2D and 3D drawing (always I give the same, for example, create another new one with other numbers for 2D and 3D: 65500-0020)
Now I have to go to Manufactor and make a new file code named 65500-0020.
Can someone connect from Inventor and create automaticly the code in the Manufactor 2012?
I just need to know how I send the "saved file" after "saved" to another program or database...
