Matt and others,
This dialog actually has nothing to do with Multi-User.
What this dialog is telling you is that the assembly (or part) needs to be
updated. In other words it is 'dirty', if you open the assembly/part instead
of the drawing you will see that the lightening bolt in the assembly/part is
enabled and waiting for you to pick it.
We display this dialog because without it you have no idea that what you see
in the drawing is most likely NOT the current fully solved state of the
part/assembly the drawing is of.
For example, imagine that you open a part, change the diameter dimension on
Hole1 via the parameters dialog. When you exit the parameters dialog the
lightening bolt will come on but the part/hole will NOT automatically update
to the new dimension. Now save the part without punching the update button.
Open the drawing of that part and you will get this dialog and the drawing
geometry will reflect the "old" dimension value of the hole not the new
value you have yet to update into the body of the part. We detected that the
part was in need of an update and warned you that your drawing may not be
WYSIWYG now, compared to when the part finally gets updated.
This same thing can happen when you move components in an assembly with the
move command (they may be constrained and an update will move them) or if
you modify a part and the assembly was never opened/updated, etc.
Hope this helps explain this dialog a little better.
Steve Dennis
Autodesk Drawing Manager Development
"Matt Hendey" wrote in message
news:F856241F32AC24AC36E4760F48CACDCD@in.WebX.maYIadrTaRb...
> Please, remove this dialogue box! Have it look at the project file to see
if
> there are multiple users or not.
> Multi-User = off, no box.
> Multi-User = on, Box.
> As a single user this does nothing for me but Slow Me Down!
> Thanks You,
> Matt Hendey
> American Mobile Power
