Are you using the Default Syles library or a customized one on your
server/shared location.
And if I understand correctly, you haven't started to do any formattting.
All you did was just open the Drawing.
Vijay
Inventor QA
wrote in message news:4858768@discussion.autodesk.com...
I have Autodesk Inventor 9 and when I open up a drawing (it doesn't matter
which one; they all do the same thing) to Format and Layer it, I get the
error: an unhandled exception has occurred in a component in your
application Click continue and the application will ignore this error and
attempt to continue. I have attached the detailed report out of that as
well. I have tried uninstallation, as well as deleting all of the program
files, but when I reinstall, I get the exact same erro
r. Any help would be greatly appreciated. Thanks.
