Inventor General Discussion
Distinguished Contributor
6 Kudos
Post 1 of 3
Autodesk 360 file - file locking across multiple locations
295 Views, 2 Replies
01-14-2013 12:29 PM
Does Autodesk 360 cloud storage work in any way shape or form similar to a Vault whereby users can check out, lock, and then check in designs? Can Vault be used in conjunction with Autodesk 360, or does Autodesk 360 eliminate or replace the need for Vault?
What's the best way for individuals working at multiple sites to work without overwriting each others' data or having save collisions?
Does Autodesk 360 cloud storage work in any way shape or form similar to a Vault whereby users can check out, lock, and then check in designs? no it doesn't work like vault
this isn't a replacement for vault
360 is not a file mangement system
its a file sharing tool its almost  like a ftp site
652 Kudos
Post 2 of 3
Re: Autodesk 360 file - file locking across multiple locations
01-14-2013 12:47 PM in reply to: dick_upton
6 Kudos
Post 3 of 3
01-14-2013 04:14 PM in reply to: dick_upton
OK thanks.
