i am a local admin on my pc
everything works except for the missing color schemes.
the box is empty...
please advise...
Hi! It seems like you got an empty Scheme registry. Launch "regedit.exe" and go to the following path.
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion17.0\System\Preferences\ColorSchemes\Schemes
Do you see subfolders there? More than likely it is empty. Do you know why it is empty? Did you change it somehow?
Anyway, I have attached the ,reg file from my machine. You can simply unzip it and double-click and the registry record will be populated.
Thanks!
