Inventor Forum
Autocad import problems into Inventor
3 REPLIES 3
JEZBEN12345
387 Views, 3 Replies
I am simply importing Autocad DWG 2d sketch files into Inventor and would like to rotate the sketch/object. This is ridiculous that this program will not easily allow me to do so. I can move/copy/scale but not rotate. I keep getting constraint error issues. Any help or direction would be amazing.
3 REPLIES 3
JDMather
in reply to: JEZBEN12345
If you convert to a Sketch Block - you should be able to move/rotate any way that you need.
If you can't figure it out - attach your *.ipt file here.
The CADWhisperer YouTube Channel
pcrawley
in reply to: JDMather
Try enabling "Relax mode" before rotating.
Peter
JEZBEN12345
Bless you! You are the best!
