Hi to all,
I do have a problem w opening AutoCad 3d model:
I open a dwg (option: Import)
accept first page - read from autocad
accept second page - all layers
on the third page 3d date: 3d solid checked
Now a problem:
changing from detected units to Specify units ( all options)
does not change size of imported 3d model
I try in autocad change insunits to in, mm.... no changes of imported model
Whats is wrong? I use walk around - derived comp in proper scale,
but why units set do mot work?
Thanks for any imput
Ursus
Solved by Ray_Feiler. Go to Solution.
Try Measurement 0 = imperial 1 = metric
Is anyone able to get this link to work?
@Uziemblo_U wrote:
JD
This a link:
https://360.autodesk.com/#/Item/Details?id=cff129c6bd62437585f592aacc4d91df&itemtype=file
JD
I'm sorry (I said i'm new to Autodesk360)
I did not turn "Sharing" ON.
Now I hope is OK
Again this is the link
In AutoCAD type Measurement at the command line. 0 = imperial 1 = metric
Ray,
Thanx a lot IT IS IT
Now import is the same size
Thank you again
Problem solved
