I made an assembly and a DWG drawing in Inventor.The DWG drawing from Inventor always stay in paper space. I could not make it to Model space. Also I could not copy and insert it to other dwg drawing in Autocad. I want to manually modify it in AutoCAD. but I could not. Please help.
Jason
Solved by mslosar. Go to Solution.
Solved by coreyparks. Go to Solution.
The file is an Inventor DWG. This is only able to be viewed in Autocad, not able to be modified. If you want to modify drawing in Autocad you need to export and an AutoCAD DWG file. This exported file will no longer be parametrically linked back to the Inventor file so any changes done will no be linked back to the Inventor model.
