OK - maybe you are missing some basic MDT tricks.
You need to convert the ACAD file into MDT parts, so pick amnew command and
select any of the the 3dsolids, watch the command line if it's telling you
about errors. You may need to explode the ACAD blocks first before being
able to convert them to parts. Do a list command of every piece - if it's
telling you 3dsolid, you won. If it's telling you block, you need to explode
it one more time. If it's telling you surface, body, or region, you lost the
right path.
Just another workaround:
Open file in MDT, do a amacisout/all, open newly created file (has the file
extension *.sat) in IV, save.
Leo Laimer
Maschinen- und Fertigungstechnik
A-4820 Bad Ischl - Austria
"Jeff Dickerson" schrieb im Newsbeitrag
news:0C586F13C848C7F96B433C431D174F15@in.WebX.maYIadrTaRb...
> I opened the Autocad File in MDT6 and clicked Part>Part>New Part and it
> added it to the browser on the left. I then saved as I "normally" would
and
> then closed MDT6 and then Opened Inventor selected File
> Open>Desktop>015Valve and it asks me if if want to translate....I say yes
> and then it opens a assembly drawing with nothing in it?
