Inventor Forum
Auto-rotate vertical text problem
3 REPLIES 3
danijel.radenkovic
279 Views, 3 Replies
Hello friends,
I have a problem when I want to export(or save as) an .idw to .dwg. When I open exported .dwg all vertical texts are rotated for 90°. See attached files please you will see what's problem. Problem started with Inventor 2015, earlier versions don't have a problem.
Thanks in advance
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
3 REPLIES 3
mcgyvr
in reply to: danijel.radenkovic
@danijel.radenkovic wrote:
Hello friends,
Thanks in advance
Danijel
That seems to be a bug or regression with "geometric" text..
If you just use regular text (90 deg angle) it exports without any problems..
danijel.radenkovic
in reply to: mcgyvr
Hello "mcgyvr",
I resolve problem by checking option "Best Visual Fidelity" but it makes new problem (all dashdot lines on my drawing are "splited" in small pieces-mini lines ).
mcgyvr
Just use regular text (90 degree rotated)..
Then the problem is solved/resolved without any other problems...
