I have a client which used to work on it. We moved the VM machine which they worked on to another host. Today I mode back the VM to the existing host and all the set up is right, Ethernet and USB controller, but when users want to attemt to open application they get an error and it asks for the machine name they have the license on. after entering the machine name the process restarts!
Please help!
Did the license server get moved? Does the server name and MAC address (of server) specified in the license file still match the server it resides on. If nothing on the license server changed, can you ping the license server from that machine?
All the information on the license file is good. I also can ping the server from the client and vice versa.
They were god last week, we just had the server moved to another host and later we noticed it needs the dongle to validate the license and moved it back to the current server.
Thanks for your response and I'll be appreciate for you prompt answer
I have received that error on occasion when I have to remote work (the application is loaded locally on my machine, but the flexnet server is at the office). When I VPN and remote, it will work fine. If I do not disengage/disconnect from the VPN correctly (IE I just shut down my machine) it locks the flexnet server and I will be unable to secure the licence until the server/service is restarted. Once that is restarted I am good to go.
TL;DR: try restarting the Flexnet server/service.
