Thanks Stephen Gibson. You are going to save us all a lot of time and effort!
Dan Wing
Product Designer
Young&Franklin, Inc.
Specialty Fluid Controls
I place the text on the leader to the balloon. Pick the leader, right click and select "attach text to leader". It defaults to the middle of the leader; but, you can slide it closer to the balloon manually.
However, I just tried Stephen Gibson's method, and I will be switching to that!
jaybear: Another good suggestion. I am always amazed at the little things that can be done that never seem to be documented.
Dan Wing
Product Designer
Young & Franklin, Inc.
****....everything was going along nicely with this solution from stephengibson. Then I needed to do it on attached balloons (balloon with multiple items attached) - it will only work with the last balloon
Surely there is a way to solve this....balloon with item number in centre & quantity (slightly smaller text height to Item no) positioned outside the balloon at lower right. If I could I'd copy the balloon style - "circular -2 entries". Modify it by deleting the horizontal line, moving the bottom text entry to the lower right at right text height. Then moving the top text entry to align centrally in the balloon & adjusting the text height. Any one been able to manage this.
Like some on here the company standards are different to everyone else. We're required to show a balloon with the item number (centred in balloon) & quantity (in smaller text) to the lower right. I've been using the leader method for some time now - can be a bit tedious as a work around.....especially when I think there is an easy fix as in a customized balloon.
