Inventor Forum
attaching fcf to a hole callout
13 REPLIES 13
Message 1 of 14
rclement
945 Views, 13 Replies
im looking to attach a fcf to a diameter call out. ive looked on here for a answer but i dont see how it work.
it says to double click text in hole callout to see green blip points. the only blip points i get is leader start and end and the diameter points on circle.not around text. i get attached but arrow head appears as well?
13 REPLIES 13
Message 2 of 14
rclement
in reply to: rclement
48 views and no wants to or can answer.geez thats disappointing
Message 3 of 14
mrattray
I don't understand the question. Can you attach some pictures to help clarify? What's an fcf?
What says that? Can you post a link to it? That may help to clarify your question.
Mike (not Matt) Rattray
Message 4 of 14
jletcher
in reply to: mrattray
It is Feature Control Frame "fcf"..
Message 5 of 14
mrattray
in reply to: jletcher
@jletcher  Ah, I see. We don't use GD&T at my shop.
@rclement I had no problem attaching one to a diameter dimension in 2013 SP2 UD5. What version are you using?
Message 6 of 14
jletcher
If you don't want arrow left click one time on FCF then on green dot near back of the arrow ( when you get close symbols will show) double click and you will see options..
I believe this is what you want..
Message 7 of 14
mrattray
I thought this was what he was after:
@rclement This is likely why your post didn't see a response. Nobody wants to have to drag what you want out of you.
Message 8 of 14
jletcher
 More then likely but I think he attached it to the dimension line aand does not want arrow.
 If he does not want the line he will just right click on the line and delete leader..
 But some want a line going to the dimension but no arrow..
Like this..
Message 9 of 14
rclement
close but was trying to not use lines pointing to dimension
Message 10 of 14
rclement
all anybody had to do was ask..thats exactly what i want but is the feature control frame attached to the radius callout.i can hang seperatly but if i move dimension doesnt move. if i use the it with seperate line and delete. it loses the associativity with the radius callout
Message 11 of 14
rclement
the only reason im asking figured there would be a easier way. before inventor i had used nx .which allowed you to add feature control feature to a dimension call out.
Message 12 of 14
nmunro
Yes, it is easily attached. When you start the FCF command and the FCF is attached to your cursor, just wander around a bit below the dimension text. Click when a green dot appears, then right-click and Continue. There are actually 8 snap points that represent the corners and midpoints of a box surrounding the dimension text. Any one will connect the FCF to the dimension.
Neil
https://c3mcad.com
Message 13 of 14
rclement
in reply to: nmunro
i tried that someone at a user group showed me was little cross hair. but i can find on mine.i there a setting i dont know about>
Message 14 of 14
rclement
ok i found it but is a curved leader promp. why is it different on different peoples computers. is this a variable that can be assigned different icon/
just wondering
