I am using "Attach Text to Leader" to add information about ballooned items to the balloon leader. The same information is needed for each balloon leader as shown below.
<COMPANY>, <DESCRIPTION>
<PART NUMBER>
Being a lazy man, I would like to just copy the fields from the first "Attach to Leader Text" and paste them in the subsequent "Attach to Leader Text" instances, instead of picking the "Type" and "Property" from the pull down lists for each of the three property I want to access, each time I place a "Attach to Leader Text" .
The problem is the fields in the subsequent Attach to Leader Text pasted instances do not automatically link to iPropeties on the ballooned item?
Can anyone share any tricks as to how to automate this procedure/
Hi RD-Digitek-USA,
Are you familiar with Sketched Symbols? You can preconfigure a Sketched Symbol to read the iProperties of your choice, and then use it over and over.
I hope this helps.
Curtis
