Good Day, maybe I'm asking dumb question, but I don't expect dumb answer. I'm wandering is it in Inventor somehow possible do update model annotatin, when I change it in drawing ( I'm using retrieve dimension for insatance). For instance in Solidworks this works just fine.
Thanks in advance.
Solved by JDMather. Go to Solution.
Are you trying to change a model dimension from the drawing?
Right click on the dimension -
Can you attach a simple example here and describe the behavior you expect to see?
(Editing model from drawing can be disabled to prevent inadvertent editing by beginners.)
I edited my response above.
Not double click - do a right click instead (see image).
Now It's working.
But, thing is that it works only when retrieve dimensions is used, not in ordinary dimensioning.
Thanks a lot.
I'm using Inventor half of the year, and I'm quite satisfied, but didn't manage to figure out this feature, and in SW, was quite easier done.
Bye
