Inventor Forum
Associating Two Sketches In A Frame Generator Assembly
10 REPLIES 10
Message 1 of 11
SteveFrey
588 Views, 10 Replies
I have sketches that are used in framed shower door assemblies and I am trying to use the main sketch as the outside perimeter w/ associated parts while the door is separate so it can pivot independently from the rest of the assembly.  My question is:  How do I associate the door sketch to change size when the door opening changes size in the main sketch?
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
10 REPLIES 10
Message 2 of 11
adsloud
in reply to: SteveFrey
Hi Steve,
For now, Inventor doesn't have such functionality to associate geometries between two sketches. We've already taken this into consideration and try to make this in the future. Thank you very much for pointing out your questions.
Best Regards,
Debbie
Debbie Lou
Sr. QA Engineer for HSM CAM
Message 3 of 11
SteveFrey
in reply to: adsloud
Thanks Debbie.  What about using a dummy parameter file to drive the sizes?
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 4 of 11
rdyson
Attached is a quick example of what I understand you are asking for
May well be wrong in my understanding, though
Adjusting either of the two parameters in the FrameSketch will propagate to the door part
PDSU 2016
Message 5 of 11
SteveFrey
in reply to: rdyson
Looks like you understand what I'm trying to do.  So from what you created I would open the Door&FrameTemp.iam and control it from the FrameSketch.ipt.  Now I just need to understand how you linked the two successfully.  It's been a while since I tried it.  I'll give it a try and let you know how I make out.  Thanks!
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 6 of 11
SteveFrey
in reply to: rdyson
Okay, now that I'm thinking about this the model you sent to me is simple enough to do without associating the frames.  Where it starts to be more complicated is when there's a door with at least one fixed panel like in the attached image.  Now the door size (26") will drive the panel size (11.027") or if I change the overall width (40") the door stays the same but the fixed panel changes accordingly.  I've done this in the SK (attached) but like I said I need the door to swing open in the assembly as a representation.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 7 of 11
rdyson
Not sure I understand the problem here.
PDSU 2016
Message 8 of 11
SteveFrey
in reply to: rdyson
That looks like it works.  I guess I'm not understanding how to link the two frames together.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 9 of 11
rdyson
PDSU 2016
Message 10 of 11
SteveFrey
in reply to: rdyson
I tried to do this many times but I'm not able to link the parameters.  Can you give me any pointers?  Thanks.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Message 11 of 11
rdyson
Tell us, step by step, what you've done.
PDSU 2016
