Inventor General Discussion
treecatt
Message 1 of 23 (1,522 Views)
Assigned colors are lost when importing STEP or Solidworks file
1522 Views, 22 Replies
09-14-2011 03:37 PM
When I import a STEP file or most recently a Solidworks part the assigned colors are replaced by the standard gray. Is there an option I'm missing to ensure the colors are retained? I am using Inventor Professional 2012.
JDMather
Message 2 of 23 (1,518 Views)
Re: Assigned colors are lost when importing STEP or Solidworks file
09-14-2011 04:41 PM in reply to: treecatt
There are two different STEP formats AP 203 and AP214
Have them set Options when saving to AP214 to carry color information.AP214.png
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
treecatt
Message 3 of 23 (1,513 Views)
09-14-2011 05:22 PM in reply to: JDMather
Thank you for the info. Generally, the STEP files I import are downloaded from a manufacturer's website so I probably won't be able to do anything about which STEP format they are in. Do you know why I would experience the same problem with a native Solidworks file? Opening the Solidworks file in their viewer program displays the device with correct color assignments so the color info is definitely in the Solidworks file.
Daniel Schuman
Emerson Excitation Systems
Employee
KevinLi-Autodesk
Message 4 of 23 (1,504 Views)
09-14-2011 08:12 PM in reply to: treecatt
Hi treecatt,
Appreciate your report firstly and I follow up your workflow and validate it at my side, but don't reproduce it in my Inventor Professional 2012. Can you attach the STEP file or native SolidWorks file that has this problem for me to double check ? or you can send it via my email: Hongyuan.LiATautodeskDOTcom.
Thanks for your support and help.
Kevin Li
SQA Engineer
Kevin-Hongyuan Li
Quality Assurance Team
Active Member
aeisenberg
Message 5 of 23 (1,443 Views)
11-09-2011 01:11 PM in reply to: treecatt
did you ever get a solution to your problem?  i have the same issue - i have a SolidWorks 2011 STEPAP214 file.  When I import into ACAD 2012, it's all 1 color.  I used to perform this process without any issues in ACAD 2000i.
JDMather
Message 6 of 23 (1,438 Views)
11-09-2011 01:16 PM in reply to: aeisenberg
Can you attach the original SWx sldprt file and the STEP file here?
Active Member
aeisenberg
Message 7 of 23 (1,423 Views)
11-10-2011 05:13 AM in reply to: JDMather
it's a SolidWorks assembly - too large to post.  it occurs though on small assemblies also
JDMather
Message 8 of 23 (1,422 Views)
11-10-2011 05:42 AM in reply to: aeisenberg
aeisenberg wrote:
... it occurs though on small assemblies also
Uhmm, then post the small assembly that exhibits this behavior.
(You might roll up the feature tree in SWx to make even smaller before zipping.)
Active Member
aeisenberg
Message 9 of 23 (1,420 Views)
11-10-2011 06:04 AM in reply to: JDMather
the forum won't allowyou to post anything over 1.5MB - just 1 part in my small assembly is larger than that.  can i email directly to you?
JDMather
Message 10 of 23 (1,417 Views)
11-10-2011 06:22 AM in reply to: aeisenberg
I find that hard to believe.
Did you roll up the feature tree to hide all features before zipping?
This file is 1.9MB before rolling up the EOP, only 913KB after rolling up the EOP and zipping.
You can zip a file by right clicking on the filename and selecting Send To>Compressed (zipped) Folder.
jmather_at_pct_dot_edu
