Inventor General Discussion
Member
0 Kudos
Post 1 of 7
Accepted Solution
Assemply problem? Drafting Improvement?
258 Views, 6 Replies
10-16-2013 04:34 AM
 Hi all,
I attached the vaporizer trial.. For the assembly, I can mate the legs and intlet to the fins but I want to make them fixed in correct alignment like one body involving all the components. I could not achieve by using joint-rigid. Could you please help me about that?
I would be appreciated if you give me some tips and recommendations as well about Inventor.
Thanks in advance
all the information is here http://help.autodesk.com/view/INVNTOR/2014/ENU/
an offset constraint is self-explanitory. this is offset from that by a distance
*Expert Elite*
844 Kudos
Post 2 of 7
Re: Assemply problem? Drafting Improvement?
10-16-2013 05:12 AM in reply to: MTorun
Welcome to the group.  As a matter of good practice, please post the version of Inventor that you are using, as well as any relevant system specs.  This will help the right people look at your questions.
As far as part 2 of your question, have you looked at the tutorials in the new Inventor Help?  Just click the Question Mark in the upper right hand of your Inventor screen.  Brand new help site, and it has a lot of tutorials you can play with to learn your way around the software.
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
*Expert Elite*
655 Kudos
Post 3 of 7
10-16-2013 05:16 AM in reply to: MTorun
need more information...
One must remember that we all design different products and do not typically have detailed knowledge about different products and their exact placement of one to another..
I don't know exactly how those legs are supposed to be positioned..
They do slide up/down parallel to the fins.. An offset constraint will fix them into position with regards to distance from the end of the fins..
Why joints vs constraints?
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Member
0 Kudos
Post 4 of 7
10-16-2013 05:29 AM in reply to: cbenner
I am using Inventor Professional 2014 Student Edition.
I prefer audio/video learning materials to draft simultaneously and quickly. Any advice for that?
Thank you, Chris
Member
0 Kudos
Post 5 of 7
10-16-2013 05:48 AM in reply to: mcgyvr
I want to make all components connected rigidly to the fins. For the legs and brackets, I want to fix with offset constraint as you said, Can you explain offset constraint briefly?
Inlets should also be fixed and aligned as their point of use must be in x-axis direction.
Why shouldn't I use joints vs constraints? Can you clarify the difference for me?
Thanks in advance
*Expert Elite*
655 Kudos
Post 6 of 7
10-16-2013 07:02 AM in reply to: MTorun
Windows 7 64 bit
*Expert Elite*
844 Kudos
Post 7 of 7
10-16-2013 08:44 AM in reply to: MTorun
Thank you, Chris
Youtube.  Just do a search for Autodesk Inventor 2014 or leave the year off for more generid videos.  There is a lot of learning material out there.  Some very good videos.
ChrisB / Twitter
Post to the Community
New Post
