Hi all,
I attached the vaporizer trial.. For the assembly, I can mate the legs and intlet to the fins but I want to make them fixed in correct alignment like one body involving all the components. I could not achieve by using joint-rigid. Could you please help me about that?
I would be appreciated if you give me some tips and recommendations as well about Inventor.
Thanks in advance
Solved by mcgyvr. Go to Solution.
Welcome to the group. As a matter of good practice, please post the version of Inventor that you are using, as well as any relevant system specs. This will help the right people look at your questions.
As far as part 2 of your question, have you looked at the tutorials in the new Inventor Help? Just click the Question Mark in the upper right hand of your Inventor screen. Brand new help site, and it has a lot of tutorials you can play with to learn your way around the software.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
need more information...
One must remember that we all design different products and do not typically have detailed knowledge about different products and their exact placement of one to another..
I don't know exactly how those legs are supposed to be positioned..
They do slide up/down parallel to the fins.. An offset constraint will fix them into position with regards to distance from the end of the fins..
Why joints vs constraints?
I am using Inventor Professional 2014 Student Edition.
I prefer audio/video learning materials to draft simultaneously and quickly. Any advice for that?
Thank you, Chris
all the information is here http://help.autodesk.com/view/INVNTOR/2014/ENU/
an offset constraint is self-explanitory. this is offset from that by a distance
Thank you, Chris
Youtube. Just do a search for Autodesk Inventor 2014 or leave the year off for more generid videos. There is a lot of learning material out there. Some very good videos.
Chris Benner
