Small problem, I screwed two blocks pinned on what I'm shooting a scope at the ends to make a thread, I can not find the thread function in module.
Even by adding the command, it is grayed out.
I think that Autodesk has never thought of that.
Regards
Dom
Solved by mcgyvr. Go to Solution.
external threads are still not supported in the assembly environment... Maybe a multi-body solid part will work for your application.
Here is the active idea that people can vote on:
