Inventor Forum
Assembly section view not sectioning FG parts
6 REPLIES 6
stevec781
4370 Views, 6 Replies
When I make a half section view in an assembly the frame generator members do not section, they remain full length.  Is this normal or something with my setup?
2012 SP2.
6 REPLIES 6
if you are talking about sectioning in actual assembly goto - Application options - Assembly and make sure "Section all parts" checked.
Thanks, strange its not set to on as default
Just to add an extra solution to this issue - if you are still having issues with FG parts showing, even after you select "Section all parts" in Application
Options, ensure you select 'Always' in the Section View's Display Options Tab:
I had mine set at 'Obey browser Settings', but changing it to 'Always' had my FG parts sectioning correctly.
johnkeane440
in reply to: forbillian
My FG parts are still not cutting automatically. Ive tried all the above and nothing is working. Its absolutely infuriating.
johnsonshiue
in reply to: johnkeane440
Hi! Do you mind sharing an example here or send it to me directly (johnson.shiue@autodesk.com)? I would like to understand the behavior better.
Many thanks!
Software Test Engineer
johnkeane440
in reply to: johnsonshiue
Heres an example of the issue with all above suggestions in place. It seems to only happen my own custom frame generated parts. The issue must lie there I assume.
