I want to create Leader Text that has a few assembly properties.
Whenever I try this, the leader displays the properties of the part, not the assembly.
If the note has no leader, it doesn't display any property.
If I add a property to the title block, it shows up just fine, but that isn't what I want.
I feel that this should be really easy, but I'm just not seeing how to do this.
I'm using IV 2014.
Welcome to the forum.
When you are placing your note, which type are you selecting? Should ne the model properties.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Ok, and after you select the correct property from the property drop down you are selecting this button to populate the text with this property?
Yes.
And it populates with part properties, not assembly properties. Whatever component the leader is attached to is what is related to the note. I want it to bring up the assembly information, not the information from a part within the assembly.
I don't think that Leader Text can access assembly or sub-assembly properties. There is an Idea Station request to change that behavior.
You might give a kudos to this and help move it up the developer's priority list.
You might add a comment there that references this thread too.
Steve Walton
What assembly properties are you trying to bring through?
As the others have said you can't use a leader for this. But you may be able to use a sketched symbol to acheive your goal.
Thank you Brendan, I don't think that would work in this situation.
I want my notes to show project iproperties, like stock number, vendor and so on.
Thank you Swalton, I bumped it!
michaeldavis7418, I made a rule that drove some paramaters I just created. It allows me to put them in my note, and they'll update automatically. Is this what you meant, or is there an easier way?
I was looking for the same thing.
What i did was make a new balloon style that shows the DESCRIPTION instead of ITEM NR.
Keep inmind, when you unfold the partslist to part level, it will show the description of the part.
Works fine for me where i needed it.
