I have created an assembly in Inventor, and everything seems to have come out right except for one thing, which I will attempt to explain: the assembled project is not parallel with any axis. For example, when I use the 'common view' method of rotation, and choose a side view, the assembly is rotated so as to be tilted, instead of showing the side of the assembly, such as what would be shown if I were to use the 'look at' command, and clicked on the side of the assembly. I'm not sure if that makes sense to anyone, but hopefully there is a person whom can interpret it into some type of logical statement, and be able to assist me. The reason I need to know this is I was planning on using the program to calculate the center of gravity of the assembly, which is an ATV trailer, and want to know where to place the axle. Obviously, I cannot really use the coordinates the program gives me (with any ease, anyway) if the assembly is not properly coordinated on the grid system, especially if there is no grid shown in the assembly file.
Thanks for your time.
