Inventor General Discussion
Member
0 Kudos
Post 1 of 5
Assembly - parts not visible
358 Views, 4 Replies
05-11-2012 12:26 AM
I'm working on a small Assy (25 parts). When I open one of the parts from this Assy and work on it then go back to the Assy many parts are not visible. The update button is usually off so I can't use it.
This started only about 2-3 weeks ago - in every assy. I changed the nvidia driver but didn't help.
Any idea how to fix this?
Inventor pro 2012
Win 7 Pro. sp1 64 bit
Intel Core I7-2600 CPU
Ram - 8GB
Quadro 2000 D
Nvidia 275.89 (tested nvidia 296.70 with no luck)
2,122 Kudos
Post 2 of 5
Re: Assembly - parts not visible
05-11-2012 02:54 AM in reply to: alon
Attach assembly with two parts - one that is still visible and one that is not visible exhibiting the behavior you describe.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
1,273 Kudos
Post 3 of 5
05-11-2012 05:32 AM in reply to: alon
Try using the rebuild all command and see if that helps.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Member
0 Kudos
Post 4 of 5
05-14-2012 02:32 AM in reply to: JDMather
Thank you.
I'm attaching 2 pdf files that show the problem. This is what I get on any assy I work on.
The no. 1 file is the assy before I started working on parts and no. 2 is what I get when I go back to the Assy.
I tried using "Rebuild All " as Scott wrote and it works - all the parts are visible again. I still would like to know what happened that caused this problem in the last 3 weeks
Alon
Member
0 Kudos
Post 5 of 5
05-14-2012 02:34 AM in reply to: Cadmanto
Thank you, it works but I still would like to know what happened.
Alon
