Now all of sudden when ever I run my cursor over parts in my assembly they light up BRIGHT RED and turn BRIGHT BLUE when I click in the empty space to deselect them.
What's going on..
Also inventor is seemlying using up more memory and project isn't that big.
Solved by mrattray. Go to Solution.
What version of Inventor are you running?
Did this just start happening? Or have you done an upgrade recently.
Can you provide a screen shot of what you are describing?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Try playing with these options. (Mine are checked because I like the highlighting.)
As far as memory usage is concerned, have you tried rebooting your PC? You could also try un-checking this option:
Check your Filter Selection, you might have gotten changed, try Component Priority.
Autodesk Inventor Professional 2012. no upgrades
Just started happening. Thinking I must have accidentally clicked on something at some point.. don't know what thought of course.
