Hi
hopefully someone here can help. When i started my assembly, i could see all of my textures. Today, it is so bright that i cant even see any shadows. doesnt matter which view i have, i cannot see the texture. there is a glimpse of it when i look iso view but that is it. I have tried altering the styles to reduce the brightness down completely but it has no affect. if i open another assembly file and place the same part, i can see the texture perfectly.
How can i change it back so when i look from the front, i can see the woodgrain laminate that i am supposed to see. i have attached 2 images. the white one is supposed to be a brown woodgrain laminate that is shown in the other image. both images where using the same style with the same setting and are the same material.
Thanks in advance,
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
The two pics that you show seem to be of two seperate view types. One looks like it is shaded and the other looks to be edges with hidden lines turned off.
Is this the case? The other thing is you might want to try and restart your PC to see if that makes any difference.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Nacho
What version of Inventor are you using?
Post two example parts--one that displays correctly, and one that exhibits the problem behavior you described.
Cameron Whetten
Inventor 2014
Nacho
