As a work around try setting it to "mirrored" then remove the prefix or
suffix in the naming screen.
Your result may be a little closer to you design intent.
Since some assembly constraints do not make the trip, you can use the new
"predict offset" in the place const. command to leave parts in place while
adding the assy. constraints back.
-hope this helps
Kevin
"BTBeilke" wrote in message
news:4B67B91EFCF03C2C116AE1E113C1B2A1@in.WebX.maYIadrTaRb...
> From and earlier post of mine on the IV7 board (pre IV8 board):
> I am trying to mirror one side of an assembly to the other. These
> particular pieces are all cut out of flat sheets of metal. Because there
> are no flanges or anything, none of the parts need to be mirrored
> (rights/lefts), they just need to be copied and perhaps reoriented on the
> other side. However, IV8 doesn't seem to be able to figure this out. If
I
> let the program actually create new mirrored parts, everything works as
> expected. Parts are in the correct position/orientation and are properly
> constrained. But, when I change from "mirrored" to "reused" parts, the
> whole thing breaks down. Some parts are upside down, parts are not
properly
> constrained, etc.
> Does anybody have any suggestions or workarounds for this problem? When I
> first read about this feature, I told my boss that it would be great, IF
it
> worked. My fear was that it wouldn't really be useable until somewhere
> around IV10.
> Like I said above, if you let it mirror EVERYTHING, it seems to work OK.
> But I had the same type of constraint issues, out of position pieces,
etc.,
> that you described when I tried to copy parts rather than creating a
mirror.
> I also discovered that if I didn't also mirror the main side sheet to
which
> the other parts were constrained, even mirrorring everything didn't work
> very well.
> Blane
