Inventor General Discussion
gsger5
Message 1 of 5 (163 Views)
Assembly file independent from part files
163 Views, 4 Replies
01-30-2013 11:27 AM
How can I make an assembly file independent from the part files that went into it? I tried converting it to STL then opening the STL document, but that causes problems with what I'm trying to accomplish.
Cadmanto
Message 2 of 5 (161 Views)
Re: Assembly file independent from part files
01-30-2013 11:33 AM in reply to: gsger5
Why don't you outline in detail what you are trying to accomplish and then we might be able to better pin point what you should do.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
gsger5
Message 3 of 5 (154 Views)
01-30-2013 11:40 AM in reply to: Cadmanto
Thanks, but I eventually figured out how to accomplish my goal with doing that.
mrattray
Message 4 of 5 (149 Views)
01-30-2013 11:44 AM in reply to: gsger5
I don't know what method you found, but the correct method would be to derive your assembly into a part document.
Mike (not Matt) Rattray
New Member
archingturtlesandsnails
Message 5 of 5 (66 Views)
12-09-2013 04:33 PM in reply to: gsger5
So, just use shrinkwrap? Any specifics? I don't want to lose my work AGAIN, so if you can please explain that a little since I don't want to take a risk.
-Aristides
