Inventor Forum
Assembly file independent from part files
4 REPLIES 4
297 Views, 4 Replies
How can I make an assembly file independent from the part files that went into it? I tried converting it to STL then opening the STL document, but that causes problems with what I'm trying to accomplish.
4 REPLIES 4
Cadmanto
Why don't you outline in detail what you are trying to accomplish and then we might be able to better pin point what you should do.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
Thanks, but I eventually figured out how to accomplish my goal with doing that.
mrattray
I don't know what method you found, but the correct method would be to derive your assembly into a part document.
Mike (not Matt) Rattray
archingturtlesandsnails
So, just use shrinkwrap? Any specifics? I don't want to lose my work AGAIN, so if you can please explain that a little since I don't want to take a risk.
-Aristides
