Inventor General Discussion
Member
mark
Message 1 of 6 (354 Views)
Assembly 'family tree'
354 Views, 5 Replies
01-22-2013 09:00 AM
Hi Everybody.
Is there a way of getting a family tree of all the parts and sub-assemblies of a main assembly?
I would like this so I can keep track on what parts need drawings (manufactured parts) and if the drawing has been done.
Alternatively, how do others keep track of this?
Mark
Valued Mentor
stephengibson76
Message 2 of 6 (345 Views)
Re: Assembly 'family tree'
01-22-2013 09:44 AM in reply to: mark
in your assembly browser RMB then select expand all, alternativly use vault
Stephen Gibson
View stephen gibson's profile on LinkedIn
scottph
Message 3 of 6 (340 Views)
01-22-2013 09:59 AM in reply to: mark
You can use the design assistant to get reports of the assembly hierarchy.
Valued Mentor
BLHDrafting
Message 4 of 6 (320 Views)
01-22-2013 12:40 PM in reply to: mark
The assembly BOM/Structured tab is a parent and child view of the assembly. Expand as many branches as you like. This can also be done in an IDW Part List.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
Member
mark
Message 5 of 6 (303 Views)
01-22-2013 02:38 PM in reply to: mark
Hi All,
Thanks for your replies. Of course, the BOM is a 'family tree' of sorts. I should have thought of that. I guess I could add a column 'drawing done'
Is there a way of seeing all the BOM in one go, like on a A1 or A0 drawing sheet??
Mark
Valued Mentor
BLHDrafting
Message 6 of 6 (291 Views)
01-22-2013 03:43 PM in reply to: mark
Either the assembly BOM Model or Structured tab (once all levels are expanded) show the tree and all parts. There are some differences. Use the wiki to discern these.
The Part LIst on the drawing uses 1 of the 3 BOM types (Model, Structured or Parts Only). And you can also export the BOM of your choice to Excel, either straight from the assembly BOM of through a macro (quite a few on the forum). Using the inbuilt BOM Export gives you a tree like look which is probably whabom.pngt you want.
Brendan Henderson
Web www.blh.com.au
